Had a bit of a nightmare since before christmas time. My car has been sitting unused for best part of a year. Went to use it again and get mot etc done, so had to jump start to get it inside and onto a ramp to see if i can minimize work needing done to pass an mot
Blah blah blah, long story short i was cleaning up terminal connectors and charging battery etc as i was always having to jump start.
Any way, What i think i did was, not connect the small wire back on the starter tightly enough as it turned out it was a little loose still.
But before i realised that i first assumed my problem was related to the alternator. Got new regulator and slip rings.
I also ended up putting a new solenoid on the starter cause when i realised the small wire was not on tight, i took starter off completely and cleaned up posts and connectors and bench tested.
Since putting it back together car will not start. Today i got a new battery as i was determined battery was still good and only needed a charge, cause it was a bosch and still looked quite new.
So blah,blah,blah, car will still not start. looking for a few pointers. and done a little vid
I've checked the coil pack getting spark from all 4 coils.
may try some easy start tomorrow.
For now i'm looking for some advice.
I'm also wondering if there is wires missing from the bit in the pic
