Goin to have a
Daz
Bash at porting my spare inlet manifold 2moz..if we are as dead as 2day in work...
Any pointers vocky?
And do i get it painted while i'm doin it....Was thinkin maybe titanium if i do?
Wot u think guys...
Andy
i wanted to have a go at mine but bottled it lmao!!!
if think if you intend on painting other bits then it would look ok, if its only the TB you are gonna paint then it would look out of place.
Daz
Was on about painting the inlet manifold andy...lol...did u read it wrong?
got silver on my engine cover already so it mite look ok...
you need to open up the exit ports, about 1.5mm all round, try and get as far into the ports as you can
then you need to modify the opening below where the tb sits
be very careful of the lefthand side (as viewed in the pic above)
otherwise the opening is only 54mm, so there's a 4mm restriction, open up carefully the lowest point of the entrance
this is the inside view, the red dots indicate where roughly to remove material
ps: you don't need to cut it open :D
Daz
Any chance of red dots on the other pic too ?....wot about the 2 platic lug type things...can they go or stay?
