Vectra C Gearbox shift linkage?
AGENTKB
Hi guys, im looking for the part no for the linkage that sits just outside the gearbox. this part is linked by two cables coming from the gear stick. This is a Getrag F23 5 speed box. Any help will be much appreciated Cheers
#2
Hi, looks like there could be two possibilities for your query :
Bracket, Support, Gearshift Control Cable to Transmission Case (Used with Wide Ratio Transmission) - Part No. 93189928
Bracket, Support, Gearshift Control Cable to Transmission Case - Part No. 93189929
Hope that may help you. :)
Oops ! - Sorry, looks like I gave you the control bracket part no(s) :banghead:, but evocarlos has given the correct part no above. :)
In fact there are two part numbers listed for this (and yes expensive !)
Part No's - Gearshift Control Cover
93189910 (£460.73) inc VAT
93176625 (£281.59) inc VAT (both from AutoVaux)
It probably depends on your VIN number as to which one you have.
