thanx go to JohnnyN for bringing up this subject cheers..
The question was what does a modified inlet system do to the fuel pressure notsure.gif
I measured the vacuum for the fuel pressure regulator using my digital manometer, range 0 - 20 mBar
The Results
standard z22se [precat removed only]
idle = 0.2 mBar suction to fpr (fuel pressure regulator)
4k rpm = 6.0 mBar suction to fpr
4k rpm = 0.2 mBar suction to fpr
so because there is less restriction from a modified inlet system the fuel pressure will not rise with the engine revs (vacuum).
the solution is quite easy, move the vacuum pipe from the inlet pipework to the side of the inlet manifold
if the fpr vacuum pipe is close to the egr pipe get a longer piece, or it could melt :roll:
use the blanking plug from the inlet manifold to blank off the inlet pipe 'nipple'
The Results
