Resource icon
Engine / Transmission Fuel Filter Replacement
Fuel Filter Replacement (version 1.0) - Replace Fuel Filter Astra G
Parts Required 25313359 – Fuel Filter
The fuel filter is located just in front of the nearside rear wheel. To make the job easier, jack the car up and support using axel stands. This gives better access.
Step 1
The first task is to depressurise the fuel rail. The thing you need to look out for looks like a big tyre valve cap, and is found near the injector rail.
Carefully remove the cap, and press the centre pin on the valve to release the pressure....
