Front Engine Mount Insert (version 1.0) - Front Engine Mount Insert
Tools Needed
Axel Stands
Trolley Jack
Socket Set
Engine Mount Insert (ebay links)
Astra MK4
Astra MK5
First, jack up the car, and support with Axel Stands
Then, using a trolley jack, support the weight of the engine by using a block of wood to rest between the jack and the sump tray
Once the engine is supported, you can undo the 3 bolts holding the engine mount in place
Remove the engine mount from the car...
