Sidicer
Hello everyone! First of all I want to apologize for my English because I'm Lithuanian myself and some "technical" terms may not be correct in this post.
The car in question that I'm having problems with is my Opel/Vauxhall/Holden Astra G (2001) with 2.2L 16V 147hp (108kW) petrol engine "Z22SE". I've had this bucket for more than a year now and since day one it has not run correctly.
I've had a bad timing chain, bad pump chain and loads of other stuff that's been broken when I bought it or broke while I was driving it.
At this time I have ONE main problem (or lots of little problems). My IDLE is very rough (a video will be at the end of this post) and fuel consumption is not normal compared to other Astras with this engine. Also if you push on the gas harder while it's idling - it almost stalls-out and then revs up. Usually when driving and giving the engine load it stutters and tries to stall out but then gets the Revs back up and drives normally.
What I've already done to my car:
I was driving until 60 seconds, then from 60 to 210 seconds I was idling (which was very rough) and then from 210 to 282 I took off
Video that I mentioned: Youtube: Z22SE Rough Idle
(edit for testing)
I really doubt that anyone will try to read that but if anyone will...
The "Simplified data" file screencaps (to see what you'd be downloading):
What do you guys think about the Intake Manifold ? This idea popped up in my head recently about the rubber gaskets where it meets the head, but at the moment I cannot change those or remove the manifold to check
I am very thankful to anyone who will read this or will try to help me, because I've lost hope...
Cheers mates!
- New timing chain set
- Water pump chain set
- New MAF (Mass air flow) sensor
- Blanked off EGR Valve and EGR Cheater connected
- New Lambda (O2) sensor (the 1st one). 2nd one is removed because no catalytic converter
- New Throttle body
- Tried spraying flammable fluid around the engine bay to find vacuum leaks - Didn't find any.
- The coil packs where already changed when I bought the car (but to used ones, not new)
- Changed the spark plugs while changing the Timing chain
(edit for testing)
Cheers mates!
