so the c20let has symmetrical hole spacing ? but there not dual mass for the conversion i need the extra width of the single mass conversion flywheel to meet the splines on the m32If it helps a C20LET flywheel is the same as the Z22SE so may be easier to check if the C20LET is the same as the Z20LEH, as it's probably a more searched out question
or ttv are just sending out astra vxr flywheels to suit lolI just realised why TTV screw up the z22se M32 flywheel, they probably use the z20leh spacing, so one bolt hole will need machining a couple of mm as it's offset on the leh
fitment and height is good and the starter ring matches but i can't deal with it being 10kg over weight
