If you have/can get OpCom it should work out cheaper than a dealer to activate.Alright, today fitted clutch switch and stalk.. However cruise control doesn't work. Tried at different speeds, 40-60 km/h..
Looks like will have to visit ECU programmer after all..
Got any suggestion/link which one is good enough?If u havnt got op-com its worth buying n its only around 25/35 quid
OK mate, was looking up in ebay..spiduu was selling them but hes not bin on since october
Negative answer to service 0x27
The reason is: 0x35
invalidKey
Negative answer to service 0x3B
The reason is: 0x33
securityAccessDenied-securityAccessRequested
When accessing [Program variant configuration] and hiting "perform coding" button, there are nowhere to input security code. At least it doesn't ask for one.Invalid key? Maybe you are putting the security code in wrong? Im no pro though
In which moment did it asksed for code?I would have thought you would need to put the pass code into op-com before changing any settings
but iv only reset a ecu with it n that needed the code. Like I say im no expert
