fitting a supercharger with shane
here some pics of the fitting of @Shane999 supercharger :)
crappy weather so we set up in the half batcave
start of the strip down
shane actually getting his hands dirty lol
a/c pump mod new homemade bolts and spacers 0 clearance issues :)
thermal gasket with the papers removed and z20net metal gaskets fitted
crash bar looks a funny shape lol
inlet test fitting
m6 rivnuts cut to make the centering spacers for the inlet
alternator modified with an external suppressor then we removed the suppressor for clearance issues
fuel rail modded,inlet fitted ,a/c pump fitted ,alternator fitted
labeling of the loom for extensions
cs bracket at the rear of the alternator
ecu wiring nearly done lol J/K :)
more tomorrow :)
Nice work, is this going to be a stage 2?
yes its going stage 2 for now as theres not much time left to get it all fitted main goal is to get it all installed and running :)
it will have
3.1" stage 2 pulley
quad pass on the intercooler
large front mounted rad
filling tee to be upgraded to option b kit later on
thermal gaskets
dewismotorsport
Isn't stage 2 over 280bhp if so what internal work has been done? Also "quad pass" intercooler? How's that piped only seen the dual pass mod.
stage 1 = 205-215hp 3.3"
stage 2 = 215 -230hp 3.3 with cooling
stage 3 = 230 -260hp 3.1 with dual pass cooling
stage WTF = 280+ hp 3.1 and smaller with cooling mods
this one should be about 230-240 with the 3.1 pulley
quad pass is the standard setup on the inlet manifold :) the water makes 4 passes before exiting dual pass makes 2 passes before exiting single pass is one supply to all 4 cores and one exit from all 4 cores :)
dewismotorsport
Ah got you now cheers, for some reason Steve said his was stage 1 @270bhp :confused:
So once I've modded the inlet to dual pass that's me in the 3+ bracket. :D
When you said quad pass I thought it was somehow different from standard :banghead:
iirc steves was 250ish ?
yep with dual pass your a stage three ish level lol
its hard to describe the quad pass other than saying ""standard"" lol
the cars running will post up some more pics and vid soon :)
day 2
new 3 legged puller was a dream for removing the stock pulley from the snout i liked it alot as you can see :)
the use of the torque wrench made all the diffrence
the tool
and no damaged to the stock pulley
the boss for the zzp pulley went on
engine loom made and extended
charger installed and loom wrapped
cs bracket at the rear is a load of bull s**t and caused all manner of problems the evo style bracket was used and is still the better way :)
the completed install all but the charger cooler pump failed
shane has gone home now i hope he has a good trip and it was nice to meet him and work on his car :)
dewismotorsport
Just looked through old messages & my bad if was 260bhp @ 11psi
Once it's complete and up and running I'll get it dyno'd and see what it's putting out :)
Great work Carl as always, did shane have the ECU pre-mapped or did he have 2 ECUS?
Any Vids of it running.
he had a 2nd ecu to run the car then sent to orginal off for base map
vid will be here in a little while when its uploaded
Another great job Evo ! :woot:(y)
shaine said it has eaten its 1st belt :) it was an alignment issue on the pulleys hopefully he has sorted it now my 1st belt got eaten pritty quick
