Fit Rear Pads (Astra) (version 1.0) - Fit Rear Pads (Astra)
tool required
wheel brace
13mm spanner
wire brush
copper anti seize grease
new pads
Axel stand and trolley jack
cup including hot water,teabag,milk and sugar add'd as required...
rite
so first off jack up the car at the rear making sure the car is in gear and on level ground hand break should be off to make it possible to remove the HB cable from caliper, place the Axel stand under the rear sill on a secure place so the car wont drop on you....
once the wheel is removed the hand break cable...
wheel brace
13mm spanner
wire brush
new pads
rite
