l7jnd
l7jnd submitted a new resource:
Fit Quick Shift Kit (version 1.0) - Fit Quick Shift Kit
Parts Required
13mm Socket
E12 Star Socket
15mm Open End Spanner
Long socket extension
5mm Parallel pin punch and socket to fit over end
Standard Hammer
Cable Ties
10mm Spanner
5mm Allen Key
Varios Screwdrivers inc. Small Electric Type for circlip removal
Mirror of some description
Step 1
Remove the top plastic engine cover to prevent damage, replace the oil filler cap.
Step 2
Find your stereo codes so you can reset it later, disconnect battery, remove lead from battery, undo battery...
