Need the GM part number for the resistors that control the radiator fan and are located on the back of the radiator. Going to be replacing my coolant setup and need to replace mine as they're goosed.
Hi milo, not been around for a while - busy golfing schedule
It's probably a bit late now as it looks like you've got things sorted but if you need it still the GM part # is:
90589723 - Resistor, Radiator Fan
