F##CKING HEAD GASKET HAS FAILED
easy peasy lemon squeezy
I did have to have the 6.000mm ball bearing pushed thru them after fitting to hone them my local machine shop did it when I had the head skimmed
the bum part is the smaller seals I had considered contacting Trevor at Andrews precision to get some normal style phosphor bronze guides made up so the use of the normal seal could work or I guess you could fit the supertech ones upside down
#24
Is this normal for a head gasket open at the corner?
I know it is open in some places but im sure it is closed at the corners
I had the head on and took it off again to double check the valves at no.9 carrier cap. Not sure if i damaged the gasket or not cant remember how they look.
The stuck valve i had was a bent valve apparently, which caused the guide to crack
Anyway got that fixed for a tenner which i was pleased with, To buy a guide itself cost i think 8 quid minimum, I took them a valve they supplied and fitted the guide
#27
Is it correct that in a new gm chain kit you are not supplied the 4 torque head bolts that are inside the head at chain end . ?
I cannot seem to find them but I have the others that I can re-use
#28
That's correct - they are not supplied in the timing chain kit and unfortunately have to be purchased separately.
If you are looking to renew then Part #: 24407225 - Screw, Cylinder Head to Cylinder Block x 4 (tighten to 35 Nm / 26 lbf ft).
Hope that may help. :)
#29
I also need to know before i put on the big chain
I am a little concerned the balance chain is a little slack i do not know if this is down to not enough oil in the tensioner or something else so i need a few opinions if possible
And a little video showing movement of chain with tensioner activated, it was twisted and then held in place with a pin in the tensioner holes to hold down plunger
#31
to be honest it would be worthwhile replacing it with that much slack
Yes you are right I kind of suspected so
The chain is practically touching the casing
Anyway I've been in contact with vauxhall they say £195 for a new chain kit. For a genuine chain kit on eBay 100 quid
Is it a gamble to go for the Fai kit, to try and get one today. a couple of people have had failed tensioner with these ones I'm sure @davegilbert has been one of the victims.
Or should I hang on a few days for genuine gm off e bay
#33
Worth waiting a couple of days and fit a genuine GM one, you won't regret it and you know the job will be a good'un ! :)
Is the main chain OK ?
Yes Kev brand new gm been sitting in a box waiting for me since last Friday
The balance chain is gm also just had too much abuse on and off a few times and twisted about etc
Best to just hang on a bit longer then
#34
I reckon so, with a latest spec timing chain kit, balance chain kit and the cylinder head sorted (with new gasket) the car should be good for a few more thousand miles. :)
Incidentally, are you replacing the cylinder head bolts, as Vx recommend this as they are 'stretch' bolts along with the 4 bolts your mentioned above ?
#35
Yes head bolts were replaced from a gm head gasket set
Its only the tork head bolts that are not brand new
#37
#38
Hit the post button by accident there damn phone and I cant edit
I thought a couple of bolts would snap cause they were hard to come out, and they were only in about 15min .
So I need to tap the threads so there are not any more problems
What I need to know is the size of tap for the holes is a 5 mm big enough or do I need the 6mm which maybe too big
So if anyone can help with the size that would be good
Or should I mean m5 or m6
were you using green permanent stud lock ?
for future reference use blue MED stud lock you wont have any problems
