pottsey
is this the engine out of the z22se strip down thread ,the one that you were putting balanced crank etc inits to good to get rid of mate who said its standard atm hehe
it is yes there was more of a demand to get this car running than spend lots on making it 300hp readyis this the engine out of the z22se strip down thread ,the one that you were putting balanced crank etc in
you almost got it bal del, derestrict the air box other than that its the old engine that made 273hp supercharged before it was removed to fit the saab enginewell id say u will have balance shaft delete, n we have allready seen n pre cat
so what else you done??
no mods to the head 154hp with an panel air filter and a cat backflowed head?
be intresting to see what power gains are had from simple cheep mods on a z22se?
you may very well doI bet we see it at PVS
gave it a good wash with the snow foam it looks good
few little bits here and there but hey it all good
What snow foam do you use mate? halfrauds only had Carplan and I'm not using that lol
Car plan is ok for basic snow foam if you don't have a lance, but Autobrite or many other wash mix from Megs etc will do the job with the proper lance
I don't have a lance But I always thought car plan was just spray on shine sort of stuff
meguiars hyper wash from the detailer range 2-3 pumps in a snow foam lance covers the car with 3" left in the bottle i then top it off with water rinseWhat snow foam do you use mate? halfrauds only had Carplan and I'm not using that lol
went all over with g10Looks really good for a basic wash now crack open the G compound and rotary
thanks matt done a bit more todayBloody impressive Carl. That's one hell of a turn around in a short amount of time.
i dont think there was enough power to give a spark there were no back fires at the time of trying to get it runningit sounds like a good theory to me, but if it was dumping loads of fuel n there was a spark why didnt it ignite?
are you stripping the other engine to see what can be salvaged? id still be interested in a head swap (you know a limited edition head with signiture n C.O.A)
