engine rebuild Nothing fancy
Pleomaxx
Okay as some of you have read in a previous post i am rebuilding a z22se for my car.
I figurer i would make a New post for Help and pictures for other if some in the future can use it.
And og i need Help to have it all at One place.
First off my plans.
Balance shaft remove.
Rebuild with all standard parts. Besides portet top dbilas exhaust manifold and Custom exhaust system in stainless.
So far the engine is competely dissasmbled.
And I have been trying to clean the cylinder head and i need Help what is good for alu cleaning i a a bit afraid to ruin og with some chemicals.
I have had it soaked in petroleum for 2 hours and then in the dish washer but in not stisfied.
And the parts i need to proceed is
Dbilas manifold (pref a used one)
Crank and rod bearing standard size.
Complete gasket and top bolt set.
Chain kit (only timing )
Piston rings.
If you Know a good place to buy it for a good price please link it is expensive as $%#@ in Denmark.
If i missed a cheap mod that i Should to when it is Our you are Welcome to point it
Pleomaxx
Thanks
I Will replace both chain Kits i just only need the timing kit i already have the balance kit
Any suggestions to a good way of cleaning the alu head ?
sadly the supplier of the head set wont ship to denmark
