Engine management and bike carbs
Rick201i
I'm looking at bike carb conversion .one thing throws me abit and that's will the 2004 astra pass an emissions test on bike cars ?
Second of all cars with aftermarket management. How do they get on come mot time with no mil light present at mot?
#3
Most decent stand alone ECU's have the option to have a MIL light.
If its all set up right it should pass mot.
I had a 2.0L 16V X20XEV Corsa B on ITB's running 280* with 12.5mm lift Kent cams @226bhp/176lbft. that passed mot....................... just!
Rick201i
Interesting.what year was the corsa and did you have the lambda sensors in place.
#5
1998
yes it had lambda in, it needed it for mixture control. also had the cat in.
guess with carbs you will not need a lambda as you will only be controlling spark with ECU? possibly idle rpm as well?
