Many thanks to CorsaZ22se for prompt dispatch to his front gate lol. K&N panel filter all fitted now
and while I was there removed silly trumpet doohicky and shortened intake to airbox. Just got to remove the grille and/or bumper to sort the rest. Now do I cut the tubing behind the bumper and completely remove the resonator then fit the 2 pieces together or simply cut the tubing? That bit hasn't been clear on any of the guides I could find. It seems you remove the resonator but no mention as to what to do after apart from "refit" lol.
On a slightly separate note has anyone had coil packs repeatedly die on them? I fitted new Bosch triples (recommended by Euro Car Parts) and shortly after my coil pack (as I found out after replacing crankshaft sensor and the car being off the road for almost a week) had died. Now I tested the coil pack and got no spark as mentioned in the previous posts and got a new coil pack. The first replacement started killing 1 or more cylinders randomly until I discovered that by pulling the transformer bit on the top towards the front of the car it ran fine but pushing it toward the back of the car cut the cylinders down. I bent the pins a little and proceeded to Euros and got a replacement even though it actually seemed to work fine. The 2nd replacement was fine at first. Then after a day or 2 of heavy testing (lol) it too died at KFC but luckily I recognised the symptoms and had a fiddle and got it working. On closer inspection it too had died the same way as the original coil pack; the middle of the 3 pins had lost contact with that metal plate in the connector block. Now after much deliberation and thinking what a retarded system it was in the first place when inspecting the orifinal coil pack, I butchered the second replacement and used terminal blocks to permanently fix the pins to the plates and the plates to the other pins, effectively eliminating any possible future problems but also voiding my warranty.
Some questions (as I know you all love my questions lol)
Question 1:
Has anyone else ever had coil packs die one after another?
Question 2:
What the hell do I do if it DOES fail again?
Question 3:
Are there any other coil packs that are a little more likely to withstand the temperatures under the bonnet and not fail? As I'm pretty sure the original and 2nd replacement packs both melted the connector block's middle plate til there was no connection! (The plate wasn't visible from the engine side of the connector block, just from the transformer side.)
Confused.com
