So then big V,
I see you are using some yank special water pump as the main coolant pump... What is it and where from (ie dealer not country lol).
Are there a LOT of changes that 'need' to be made to repalce the std item, or can it simply be a take off from the old housing, to pump to thermostat housing ?
What of the old pump needs leaving in to keep oil/water ways happy?
And I think I saw its got 10K hours MTBF.... is that really believeable for a car thats used daily for approx 15Kmiles/year?
As I couldnt see in your build thread the exact steps for the water pump bit
It makes sense if I want to do the chain again, and drop the engine to take the balancers out + bin off the water pump in one hit.
