hi, i know this might be on here but cant find it. I was wondering if u take the egr pipe out of the manifol by the throttle body n seal the whole in the manifold can i leave the egr pipe connected still?
sorry wrote that a bit wrong i meant can u remove the egr pipe completly n seal both side but leave the egr valve untouched or do u have to blank that aswell?
If you fill in the hole on the manifold then blank off the hole in the front of the head you can leave the egr in its original position. You could aswell as that get your self a cheater and remove the egr valve completely and just use a blanking plate were it used to be. iv just done mine and its a much neater job.
