Ecu reprogramming
win.walid
Hello..
Help please
I had on my 2.2 z22se vectra b a 62 Amh battery when I bought it.. the battery dead.. I disconnected it from the car for a night to buy a new one.. but had a look on the car guide I saw that the suitable battery is 66 Amh.. I bought one an connected it, but ... when I started the engine, it started strongly .. ok .. after 30 min driving I had on the dash board ABS light with TC light.. after diagnostic by a tool I had this.. see photo .. what should I do ??
Thanks for help
win.walid
Thanks..
But when we say ECU.. does that mean an ECU which is special for ABS system only..or the ECU of the car for all of the systems ?
Is there any relation between the troubles and the new 66 Amh battery?
vx-chris
Its a special ecu just for the abs mate and i cant see the battery causing the problem but i could and very well might be wrong on that. As Carl says check the connections first
win.walid
Thanks all,.. but today I had a new problem :(:(" a car with spanner " light appeared:banghead:..and a troubles with the transmission started..
Is there any relation between all of these problems(n)(n)..again all of these appeared after the battery replacement..when I replaced it, I disconnected the "negative" first and then the "positive".. when I placed the new battery I connected The "positive" and then the "negative"..is that good or not ??, is there a relation between the connection way and the troubles ???!!!o_Oo_Oo_Oo_O
Thanks for help
win.walid
Hi all
I am still with same problem, I disconnected the new battery for a night .. after reconnecting, all of the light disappeared for a month then came back..
I cleaned the connections of the ABS ECU.. then reconnecting and connecting the battery.. the disappeared for some hours and again came back, but now while driving the lights of ABS/TC once ON, once OFF :banghead::banghead::banghead::banghead::banghead:, does that mean that the ecu is OK but again the connections?????
The light with the spanner is always ON, I have now U2104 code
Many thanks for advise
HarleyPete
That code comes up as this: U2104 CAN-BUS reset counter overrun C-05 not sure what it means though sorry. I wonder if it's a duff wheel sensor maybe?
HarleyPete
Someone will probably correct me but ABS/TC would use the wheel sensor to determine which system needs to be in use. Maybe a failing sensor is throwing up the issue and turning the light on and off. Thinking about it, my old Zafira did that on occasion when it lost traction. Is the light on all the time or just now and again?
win.walid
Thanks all
New tires NO, but I made a wheel balance recently, but the problem was existed before !
I appreciate all your thoughts but what is mad me is all of this happened after the new 66Amh battery fitted??!!, I am thinking about electrical current or voltage or even electrical shock for the ECU as a result of high current or voltage for a second..I checked the battery once again and every thing is ok
