What about some foam you could cut to shape, and then cut a hole in the middle for the red bull can?
http://www.starcase.com/foam.htm
z22se-mark said:an excellent random thread,
Mark_G said:Aluminium cans aren't magnetic thoughblue se2 said:what about a magnet?
Daz said:How about some of that foam type stuff florists use for flower arranging....cuts to shape well and will hold a can pretty well also
Mistar_T said:foam may not be a bad idea... but i think it may be a little too soft to do the trick... the thickness of it would only be around half a cm to a cm thick around the can... dont think it would be enough to support it. :eh:
