Hello friends, I need to know if the screws that tighten the crankshaft cap, should be changed or not (I guess so, but I can not find them anywhere)
attached here the image, would be the screws that tighten that piece
thanks
the screws that tighten to the crankshaft you say? is that I would like to change them ... by the way ... the screws of the connecting rod foot must also be changed? Like the screw that tightens the pulley dumper, is it also necessary to change it? It has a lot of tighten that screw ...
The connecting rod cap bolts need to be replaced.
the lower crank case to cylinder block are not as important and can be used twice. gm do recommend they get replaced every time though. same goes for the crank shaft pulley bolt.
