Hi all
I have Opel Vectra B 2001 Z22SE with couple of problems . The newest one after the chain broke a tensioner and "jumped" over the intake shaft and the engine had to be opened and ECU removed in the process...
The Cruise controll doesn't work as it should ! some times i have to push 2-3 time untill it holds. if it is workin and i step on the throttle and then let go ...it won't hold the speed it was at ( turns itself off ? ) If i increase spead with one click or 2 or 3 on the stalk it would do it Ok . But if click and hold the acc. button it would increase and when let go... instead of keeping the speed it would turn itself off...and i would have to activate it again.
it did not have cruise control ! i had to install the cc stalk and clutch switch after that activate it in a dealership and had no problems with it till now ...
any ideas ?
Thanks
any ideas ?
Thanks
