Nellyboylee
- Thanks for a bit more info Kevin, im a bit lost when it comes to the inside of the engine although I know how things work and learn really easily, I will go and check those things now and report back my findings, much appreciated...
- Hi Graham wow how very kind, you may know a chap called Steve Cooney who suspected the chains too, he had his scanner on the car, although he is busy for about a month before he could get to the job, Hopefully I can be some help to you to should you need,
