nathann88
Quick easy question for an easy job.
i need to replace the coolent iv done it before but carnt remember if theres anything you need to do?
Dranning is via the tap on the rad, is it a case of then flushing and then replacing with new coolent. let the engine get up to temp and look/refill etc.
or do i need to undo the 13mm on the water pump to refill it, to allow the air out?
thanks in advance nathan
