I did have DBilas cams to start with, good top end power delivery but rubbish idle and no low down/mid range power. Swapped to Schrick cams and back to stock manifold from the DBilas one and picked up 6bhp top end and a much better midrange power delivery and smooth idle. Both set ups mapped by Courtenay sport as UK has no retailer who can install DBilas software or didn't back in 2003-2008. This was on the N/A build engine.
On the supercharged build I am on Comp cams stage 2 blower cam but about to switch to a stage 3 Cat cam pair mainly because I need to use the brake vacuum booster driven off the exhaust cam but hope to gain a few bhp as well?
vocky or
evocarlos may be able to shed more light on to this with part numbers or profiles as well.
Are you building N/A or supercharged?
