brake creep??? the pedal will drop when engine is running due to the brake servo, this is ment to happen if it doesn't then you have a problem.
if the pedal drops/creeps with engine off and after several pumps of the pedal then you have a problem too.
as for the clutch fault, make sure you have fluid to master cylinder, remove pipe, then on cylinder outlet, remove pipe again, not sure if your car has it but some have a check valve in clutch circuit, follow oil lines from master cylinder and check fluid comes from every joint when open and pedal pressed down. if no fluid then master cylinder is shot.
