chris_carpenter
i thought i would start thread on my go at a supercharger build
i will start with the my idea of what i want i am not after huge power numbers just want it have little more under the hood so i am work to the very bottom of the scale
so to start with the strip down
a test fit to see what needs to be adjusted
so i trimmed back the rad fan cover as it was hitting the TB and the air con system got ripped out it never worked anyway and extended the loom
the water pipe in the left took some thinking about and went to round the side of the pulley
using two pipes just need a joining section to put them together
i need to make a bracket to hold the senor on the top of the manifold
have used new hose to do all the air pipes
and added to the main inlet pipe sensor and brake servo
any major things i have missed so far shout up i am here to learn
