Hello guys,
My car is Vectra 2.2 Elite Direct Auto, year 2006 with 50K miles.
I was having a slight rattle on cold start, the engine seemed a bit noisy on idle (seems fine when running) and rough gear changes, so after reading lots about it, everything pointed towards timing chain. So after lots of courage and not able to get hold of Benny, I eventually decided to get it done from Vauxhall. Just 2 days back, I got both the timing chain and balance shaft chain kits replaced by Vauxhall along with engine flush, new oil and filter.
But the problem now is that even after getting all this work done, the car still pretty much feels the same. Yes, the rattle on cold start seems to have gone and the car runs slightly smoother. But the engine is still noisy on idle (you can hear it sitting inside when stopped anywhere in traffic) and gear changes are still rough.
Having already spend a big amount on chains, not sure what else to do. So, need your help guys...
Thanks in advance.
Thanks in advance.
