This is the second version of Cliff version By-Pass. On his z22se engine he has now 1 liter oil consumsion of 6000KM. Before this By-pass he has 1 liter oil consumpsion 1200KM.
It works perfect for his Z22se engine. Last zaterday we have it also don on my Zafira a Z22se engine.
By-Pass 2016 uitvoeren bij Cliff van het Opel-Forum.
Information:
My Z22se engine
KM stand: 227.xxxKM
Bild:2002
Olie type: 5W40
Oil Consumsion: 1 liter op 800KM.
I have tried already more things to have less oil cunsumsion. Nofhing helps on this moment.
1. PVC valve checked end cleaned between cilinder 2&3.
2. Different 5W-40 oil tried already Kroon, Valvoline, Techno olie, But nofhings works for less oil consumsion.
3. Installed a oil catch, becourse off dirty airfilter end throttle body. Now everything keeps clean.
4. Outside z2se engine looks nice en clean no oil to see.
5. Inside exhaust looks very dark looks like burnt oil.
I have now my Zafira A olmost 2 years. drived almost 34.000KM with it. From the beginning I had an average oil consumption of 1 liter of oil
on 1200km . But since a few months, I have an average oil consumption of 1 liter per 800km .
Therefore, decided to try it out because his z22se block the oil consumption is considerably reduced back to Cliff ( Opel forum) the by-pass .
He has now been driven 2600KM and the oil level is still full 3/4 (80 %).
That's why last Saturday with my son Lucas all the way to Rotterdam 200km one way to perform along with Cliff the By-pass for my
z22se block. Once arrived here immediately looked at his amazing nice Corsa where a large 2-liter block is in . Same great course talk
our Opel . Then put inside the Zafira and in first do a bakkie . During the coffee let you see if the correct valve cover gasket
had me .
Z22se Valve cover gasket.
You need a clear look good if you have this right because the oil valve cover gasket there are two versions . You have a clear
a gasket for the engine t / m code : 11144979.En a gasket for the engine code from 11.14498 million and also have a different valve cover gasket.
My Z22se block has the code 110XXXXX . Comes from March 2002 year built in Rüsselsheim .
Zafira a:
Began disassembling the parts
1. Air Duct
2. coolant hose that runs along the valve cover .
3. Ignition removed
4. Remove oil tank .
Valve cover loosening some screws properly. It did have the problem that we fuel line did not get loose. So we tried to get it loose without gasoline to release leding . Succeeded but would have been better if we had gotten loose petrol Leidig maarja . Z22se valve cover removed ;
inside valve cover;
Top lid ;
2. foto klepdeksel na demontage
After we removed the lid. One looked to be as clean as possible because the inside
it was well below the oil. After we cleaned it as best as possible. We heard when you rattle with
the valve cover moving a flap. That door we heard not move when it was still not clean.
We especially crankcase vent cleaned as well as possible. There was quite some stuff from what
has been firmly. But Cliff did this by +/- 9bar can clean. : Thumb Cliff also learned that my
lower block has only five holes while my valve cover has six openings. We were together very weird.
For Cliff told me that his z22se 6 holes was in the bottom block and the cylinder head cover what seems to us to bed.
Where Cliff came back was that was used two other openings at me as crankcase ventilation compared to its
Z22se block. This we have together never be able to find information about. So it seems that there are different
versions.
Bottom block Z22se has 5 openings;
Rocker cover Z22se has six openings;
Timing Chain Z22se ;
Here Cliff start drilling a hole in the valve cover for the By-pass .
Valve cover by-pass run :
Drilling valve cover;
Crankcase Ventilation Z22se Bypass ;
Placing screw compression fitting ;
Back mounting gemodiviseerde z22se rocker cover ( By -pass) ;
Klepdeksel
EGR blindplaat gemodiviseerd;
Total picture Z22se By-Pass ;
Valve cover by-pass pipe to EGR valve ;
I want Cliff hereby once again thank you for the very nice day. And of course, for making this Z22se By-pass .
My son Luke loved to work on the car. We'll keep in touch.
