I swapped out my std Vauxhall head unit for an aftermarket stereo. It's a motorized flip up screen. There is a low pitched sound constantly if I turn the steering wheel it changes. Any ideas guys
Does your car have electric controlled power steering? if so you may need some kind of suppressor or choke on the stereo's wiring to stop this.
decent head units used to come with them in the loom or built in.
I've never used budget car audio. never really seems to be much good.
years since i have come across this problem. last time was when i started driving nearly 30 years ago
