Cam locking tool
tfb you dont really need one when doing a full chain change
only for checking aliment after the links dont match up with the marks on the sprockets
trick is not to move the cams when the chain is off as they jump once moved to far in ether direction
Thats what i need it for the new chains are on need to check it
when i did mine i fitted them with the marks in line rotated the crank 2 times to check all was ok then visually inspected the timing marks and cam locations
as long as you dont turn the crank anti clock wise your ok :)
the other trick is use a silver marker to mark the cams to the cam bearing cap but thats before you take it all apart
