Hi, I have started to collect parts for a new engine in my Vx220. I was initially planning to find a Z22se, install forged rods and an Eaton M62.
But by chance I came across the following parts:
a complete z22se Vx220 engine (exept pistons and rods)
a complete B207 engine (exept pistons and rods)
Following parts has also been sourced:
New Rods Eagle CRS5765-CC
Forged Crankshaft Courtney (built with trigger wheel for z22se)
Flywheel Courtney M25OL-22se
new Compcams stage 2: 113301 & 113302)
SC Eaton M62 stage 2
New bearings
My plan is to use the B207 engine and install the stuff above.
I am looking for an engine with 10:1 compression and low boost on the SC.
I however have some questions:
will the Courtney crankshaft and eagle rods work in the B207 block?
If yes: What pistons do you recommend (10:1)? I believe the block have no need for rebore.
Can I use Wiseco pistons made for Z22se?
New bearings
