Sweet, was thinking of using them with the standard pads as i`ve read the ebc green stuff arn`t to good at initial breaking only good when they have been used a bit and up to tempreture
the pads are diffrent now. they have a better coating on the pads so i works from go i really need a new set of brakes aswell im a bit right foot heavy and do lots of hard braking how much are u buying the discs for ?
If you can afford to upgrade to the 308mm disc set up then it is more than worth it. I have these on my turbo and they have a lot more bite then the 288mm disc`s on my old 2.2
