HarleyPete
Hi all,
The evening before last I had been in and out of the car a few times running around. Got into the car and turned ignition on to be confronted with the warning lights that indicate a door/the boot is open. At that point the wife also mentioned that nothing else was working (I hadn't noticed as was too focused on the warning lights). Nothing I tried would sort it, switched off and re-started (at this point the engine management light started working correctly), still nothing, even tried the dash panel instrument lights dimmer to see if that was the issue. Anyway, drove to where I had to go and then jumped on my phone to investigate the net. After some reading which included frightening references to having a shot CIM, loose connections in wiring looms or loose plug on ABS pump, alternator on the way out, I was starting to panic. Well the final page I read had a mention of pressing the trip reset and, voila, the whole dash sprung back into life as soon as I touched it. I have no idea what it would have been and why that would have sorted it.
Anyone have any idea as to why this would happen and if there is an underlying cause as to it happening so I can be prepared.
Cheers in advance for any help.
Pete
Pete
