Big end bearing clearance
Hi all
Currently forging a z22series and I'm measuring everything as I go. Found an issue with the clearances after the bigends.
Spec says 0.041 to 0.043 I have 0.08.
I have used the usual Gm shells set.
Looking at the spec Crank size and big end size Gm provide it seems minimum size possible going by their shell size is 0.06.
Is this tolerance a misprint. ?
Or is it 0.041 all the way round in which case in in spec.
