prolecs
Hi, Help required please!
2003 Astra G with Z22SE. Low volts from the alternator, like 11.5V at the battery but maybe up to 13.5V driving. But regardless the current is not sufficient to keep the charge in the battery so it slowly goes flat after a few days driving, and although a new battery, it needs regular charge from the mains.
Tested the diode packs and they seem like normal diode function. I swapped out the alternator with a spare that used to work ok, but same issue.
Bought a new regulator and replaced that but want to bench test before going through the hell of swapping it out. Auto electrician just shook his head and said it can't be tested on the bench as it's electronic - I assume he means the alternator is controlled by the ECU or some other device in the car?? Anyone know the details and/or a bench test method??
What sort of signal comes down the little auxiliary blue/white to control the alternator output? PWM? Voltage?
Also I notice there are two little square pad "terminals" on the back of the alternator, that look like test points. They are connected electrically so maybe I can bypass the regulator to test the full output.
Thanks
Thanks
