Astra MK4 2.2 Sri overheating
Evening folks, got an issue with the car (again!). For the last couple of days the car has started overheating if i put the heater on the temp gauge drops right down but I've got to put the window down to stop my face melting. Any ideas?
milo
when u say overheating where the needle climbing to? Is only over heating when on tick over or when on the move also?
milo
losing coolant? Oil/water mixed? Is your fan kicking in? I had an issue where my fan was not kicking in at 90 (middle) and the temp would just keep climbing, but i never let get any were near red. I changed my coolant module and never had an issue since. But the car over heating that much will lead to he gasket failure.
#5
coolant is still nice and red no oil in the mix. i'm not 100% sure the fan is kicking in. will take a look at the cooling module in the morning. thanks for the advice.
#7
Hi Vocky thanks for the reply. whipped the thermostat out today chucked it in a pot boiled it and got no movement so it is definitely stuck shut. i've ordered a new thermostat and a temp sensor.
