Gazza submitted a new resource:
Astra Headlight Replacement (version 1.0) - Astra Headlight Replacement
Parts needed
Small screwdriver
New lights
Alan key
8mm spanner
Time taken
Took around 30 minutes that was with taking pic’s at the same time.
Step 1
Fist pull up to a wall and turn on you lights and put them onto full beam.
You should see the lights on the wall you need to mark around the out line of the lights it should look like a triangle.
Step 2
Remove the front bumper see other how to guide if you need help with this.
Step 3
With the front bumper off you should see 2...
