astra coupe edition.
figo126
Standard internals will be fine upto 11 psi, after that it's risky, I tried running just over 1 bar and it let go within ten minutes, get it done pal,,
figo126
so after making a hybrid z20net/jaguar supercharged inlet manifold, ran it for a few weeks to see if it would work running charge cooled ,,got inlet temps down to as low has 12 Celsius,so very happy with inlet temps, but have strange things happening when running sometimes,,,,
figo126
decided to move charge cooler from the inlet has it was causing running problems ,, so decided to put it before inlet manifold , moved battery to boot for more room , fitted charge cooler not happy with how it sits ,,
figo126
got charge cooler brackets fitted , inlet pipes in place , radiator needs moving forward to miss charge cooler ,hope its going to be worth it,,,,
figo126
no I didn't do the balance shaft delete on this engine ,, I was using oil on the old engine before I blow it up ,, had a idea it had something to do with the b/s delete , so didn't do the forged engine ,, and not used any oil ,,,might have been something else ,
Done well there mate.how much do you think the std pistons would hold.do you have any pictures of the bulk head where you hit it to allow fitment of the turbo?
figo126
ian ,, pics of before and after smashing bulkhead in,,,
figo126
I have about 20mm at back of turbo after panel beating bulkhead, as you can see in pics you have none before, I also ran brake and clutch pipes into bulkhead to avoid heat from turbo,,
