Hello
I am looking for some help and advice on a Astra 2.2 SRI (2002) full hist and 60k on clock.
Symptoms are:
Idle:
The car idles perfectly from cold start, but on wide open throttle it stutters on pick up then smooths out to red line. Feathering throttle is much better.
Warm idle sometimes a very slight lumpiness, but only noticeable because cool idle is so smooth.
Driving:
When cool it will take wide open throttle in 1st 2nd 3rd gear to redline. But when warm it accelerates to 5000 rpm (3rd gear) then no more acceleration atall. EML flashes, no code.
EML goes off when you cruise again. When warm, in 3rd if you feed throttle from 50 it seems to
behave much better, and will move through to redline sometimes. No EML activity.
The EGR has been blanked and the throttle body cleaned with some improvement when engine cold but symptoms return when it's warm.
Any Ideas on what to try next, I spoke to a garage and they said to replace ECU but that seems quite a major thing to replace to see if it works...
Any advice would beappreciated
cheers
J
Symptoms are:
Idle:
Driving:
cheers
J
