fuzilla
Hey guys!
I've noticed that my Astra 2002 Z22SE engines cooling fan doesn't work.
So far I've replaced the cooling fan, both heater resistors on the fan, the control unit behind bumper for AC and cooling fan and it still won't work.
Also tried taking off the plug from temperature sensor, which I think should start the fan always, but in this case it doesn't.
Also checked the temperature sensors with OP-com and it shows correctly, so I don't think the problem is there.
Actual relays I couldn't find anywhere for the cooling fan, are there any?
Although the control unit and one of the resistors were pre-used parts, so no guarantees there.
Any ideas what to check or replace next?
My car does have AC which also doesn't work. That's actually why I started looking at the cooling fan.
