don't know if any software available to delete the aircon ,, when I took mine out there is 2 sizes for aux belts ,, one for 2.2 with aircon and smaller size for 2.2 without ,,
I've deleted the whole aircon set up including the evaporator. I'm putting the car on a diet .I want to retain the seats and keep it as a daily car. I think the next bit will be chop the spare wheel well out and plate it.ive measure the boot floor and it measures 29inches in diameter. I could remove the spot welds and remove the well and drop the plate in it
Let me know if you need the VX220 Aux belt i never did mine.
Just took the repo saw to bulkhead and cut the tubing out to get at brake lines tha failed MOT at 6 yrs old.
I have a factory bin wherein the EGR and the A/C is disabled. I wrote about it here. But I don't see the importance of the latter. Aircon can be turned off with the ECO button. Why do you want to disable it from the ECU?
