I've just fitted silicone intake from the TB to the air filter what's the best place to fit temp sensor as the stainless pipe gets hot I'm go a make a heat shield for it soon
Thanks sjdickso I'll get it sorted tonight got a thicker stainless pipe deliverd today as that one is just a tad to small in diameter .fitted a cold intake aswell last night not 100% finished yet tho
