G'day from OZ, Considering how much work is done under the car to do the chains, what is the best way to get access. I don't have ramps. Will the regular jack work or impede me. Do I need axle stands or will it get in the way.
Considering I have to buy most of the tools and another jack (engine mount) I'm hoping not to waste too much money. May seem like a dumb question, but remember those "Oh bugger I can't get to it" moments.
Relying on bus and shame train, so hoping not to have to stop half way through and catch a bus to get something I need.
What gaskets will I need. Not sure of what comes with the kit. And Holden will NOT give out any info, won't even give me the part numbers.
Also, is the crank seal and bolt included in the kit or do I need to buy them seperately.
Also, how did you torque the crank and cam bolts. Did you have to attach a long pipe to the end of the torque wrench ?
Looking at the pictures, there seems to be a small hole next to the crank right where the purple link goes on the cog. I was thinking of making a small spring clip to fit in the hole and hold the colored link on the correct tooth while I install the guides. What do you think ?
Changed the oil and filter and started the car and it was purring like a kitten. Whoo Whoo !!
Turned it off and started it again. Oh bugga, rocks are back !!
Thank you to all the contributors. Finding this was like finding a gold mine.
2001 - Convertible . 78,000 KM.
