Hi guys, would it be ok to swap a abs ecu on a 2.2 direct with a 1.9 one? as havive issues with abs/tc light on all the time after. Changing out hub and renewing wiring and still same problem . Thanks
Some of the newer Vauxhalls have the ABS unit coded to the car so can not be swapped without being divorced from old car then remarried to the new car. not sure if your car will fall into this bracket?
This company is very good at re working ECU's and ABS units.
Thanks for your reply man yeah i had a inkling that would be the case. Just that ive got a spare one from a 1.9. Have you had work done with them before?
