hi all (and happy new year)
My partners vectra b 1.6 16v had developed a C0121 code relating to valve relay malfunction which is inside the abs module,
the speedo worked fine just no abs as the abs light was on. i sourced a used module with pump from germany, split the module from the pump and fitted it to the car, now abs light is still on but speedo and odometer dont work, original module was TRW - replacement is kelsey hayes although all part numbers matched up.
my question is, do the pump and module have to be replaced together or need programming etc
Thanks
Thanks
