Abs connector
Discussion in 'Electrical' started by Appie07, February 21, 2018.
  1. I have some fault issue with the ABS/TC . Reading the fault codes bring up a fault that days there is no communication with ABS/TC
    I saw in the forums that people replaced the ABS module to solve the problem. Although I also saw that it can be fixed by cleaning the connector .
    Can someone tell me how to undo the connector after taking the relay box out?
    I hope I can fix it cheap :cry::cry:
  2. Thank you Evocarlos! That is a real big help :)
    I'll update it here once I got it sorted out .
    • Like Like x 1
Matched Content
