I see the A20NFT head gasket is now also easily available to buy, I know Vocky preferred the B207 head gasket on supercharger builds. Is the A20NFT better still ?
I believe the A20NFT will have extra holes for the extra oilways for the VVT? evocarlos and vocky will confirm or reject this though?
I got mine from America with the rods and pistons or with the ARP head stud kit? It's the thicker gasket which will give a lower CR over the stock Z22SE one.
